Can FlexControl be programmed to automatically mute the audio on the prior slices? TNX.
Dave - W6OVP
Dave - W6OVP ✭✭
edited October 2019 in SmartSDR for Windows
Can FlexControl be programmed to automatically mute the audio on the prior slice? TNX.
  • Mike NN9DD
    Mike NN9DD ✭✭
    edited October 2019
    It can be programmed to control volume for sure. Go into settings in the menu bar and pick Flex control and pick volume from list. Mute maybe one I don’t know but volume definitely and spin know to reduce quickly Mike NN9DD
  • Bill -VA3WTB
    Bill -VA3WTB ✭✭✭
    edited June 2018
    You can use FRstacks, it will mute inactive slices so you can hear the one your working on.
  • Dave - W6OVP
    Dave - W6OVP ✭✭
    edited July 2018
    Thanks, Bill. I'll take a look at it.
    NEXT: Is there a way to automatically switch TX ON to the active slice? (It's too easy to forget and transmit on the wrong slice...)
    73 Dave
  • Larry _ NY8T
    Larry _ NY8T ✭✭✭
    edited June 2018
    Frstack does that also
