Can FlexControl be programmed to automatically mute the audio on the prior slices? TNX.
Dave - W6OVP
Can FlexControl be programmed to automatically mute the audio on the prior slice? TNX.
It can be programmed to control volume for sure. Go into settings in the menu bar and pick Flex control and pick volume from list. Mute maybe one I don’t know but volume definitely and spin know to reduce quickly Mike NN9DD0
You can use FRstacks, it will mute inactive slices so you can hear the one your working on.0
Thanks, Bill. I'll take a look at it.
NEXT: Is there a way to automatically switch TX ON to the active slice? (It's too easy to forget and transmit on the wrong slice...)
73 Dave
Frstack does that also0
- 633 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 928 Genius Products
- 339 Tuner Genius XL
