LDG 200 AT Pro II
Barry Young
Good Morning. I had my LDG 200 Pro II Tuner connected to a Yaesu 991A. It is now connected to a Flex Radio 6400. What is the best procedure to follow to do the initial tuning? Does the unit need to be reset? Thanks
No need to do any reset on the tuner. In fact there is no reset capability.
as for tune process.
1.set SSDR Tune level to about 20watts2. click TUNE in SSDR3. If AT200 Tuner is in AUTO TUNE mode then it will immediately start tune search if SWR is above threshold point
4. if tuner is NOT in AUTO TUNE mode then push TUNE Button on AT200 and it will start tune process
5. when tuner is done, click TUNE off in SSDR
i do this all the time with flex 6600m and a LDG AT1000proII
Paul K3SF
Thank you so much for the information! Take care!0
Newbie question. If the 6600 has a internal tuner, why is the external needed? I have one coming Tuesday and have a cirro loop which has it's own ATU but is needed due to the loop control. However am thinking of getting an alpha 34' end fed wire which has a similar device like Chaneleon and was wondering if the internal tuner is up to ****0
I have a 6400. I had a Yaesu FT 991A w/ internal tuner and in my opinion the LDG 200 Pro II is a better tuner....0
I use an external tuner, the LDG AT-1000pro. The procedure is easy with FRStack: Set tune power to 10 watts and program a key in FRStack. The AT-1000pro is in Auto mode. I use ALT-T to tune. Vy 73, Alex DH2ID0
I have the 6600m which has the internal tuner BUT I also use an Elecraft KPA500 amplifier. That is why I use an external tuner like the LDG AT1000ProII
One tuner to rule them all ;-)0 -
I have an ldg600 pro model but quit using it because it wont let me set a target swr below 1.7 am I doing something wrong or is this a limitation of all ldg tuners went back to mfj because of this apparent limitation.0
@K7LER - The internal tuner tunes to 3:1 SWR. The LDG tunes a much wider SWR range. Also if people are using an amp they would want to use an external tuner after the amp, not before.
SGC auto-tuners have the same "problem" - even worse, they think less than 2:1 is OK, even when they are capable of a much better tuning solution. Sometimes you just need to be lucky to have the auto-tuner find a "good" solution. Ted VE3TRQ0
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
