Iphone willl not connect to the server
Garold  N0FIB
Garold N0FIB Member
when I live in Mt Pleasant Iowa  my iPhone worked great to use  the program to connect to my Flex 6300   Now that i have moved to Newton Iowa  it will not connect to the server  it dose work on local wifi network  jus  not when out of house  on Cell network or  other wifi networks.  why?
  • David Decoons, wo2x
    edited June 2020
    Hi Garold,
    Your router at the house needs to support either Universal Plug and Play or you need to do port forwarding on the router.
    If you post the model of your router someone here may have the same one and have info on how to set it up.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited June 2018
    Before you ever attempt to connect to Smartlink be sure to exercise the network test and see that you get the green circle. If you get a red circle, you have a network problem which most probably is related to your router as Dave said.
    Jim, K6QE
  • ThisUserDoesNotExist
    ThisUserDoesNotExist Company Adviser ✭✭
    edited December 2019
    You may also want to have a look to the SmartSDR iOS manual. The last chapter explains some common SmartLink issues and their solutions.
    Marcus, DL8MRE
    edited October 2018
    Scam
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    edited October 2018
    We are getting quite a few of these here lately, all pointing to some bogus "support site" :-(
    Gerold,
    just wondering if you were able to solve the issue and want to share your solution.
    Thanks.
    73s,
    Marcus, DL8MRE
