Iphone willl not connect to the server
Garold N0FIB
Member ✭
when I live in Mt Pleasant Iowa my iPhone worked great to use the program to connect to my Flex 6300 Now that i have moved to Newton Iowa it will not connect to the server it dose work on local wifi network jus not when out of house on Cell network or other wifi networks. why?
Hi Garold,
Your router at the house needs to support either Universal Plug and Play or you need to do port forwarding on the router.
If you post the model of your router someone here may have the same one and have info on how to set it up.
Before you ever attempt to connect to Smartlink be sure to exercise the network test and see that you get the green circle. If you get a red circle, you have a network problem which most probably is related to your router as Dave said.
Jim, K6QE
You may also want to have a look to the SmartSDR iOS manual. The last chapter explains some common SmartLink issues and their solutions.
Marcus, DL8MRE
Scam0
We are getting quite a few of these here lately, all pointing to some bogus "support site" :-(0
Gerold,
just wondering if you were able to solve the issue and want to share your solution.
Thanks.
73s,
Marcus, DL8MRE
- 997 Maestro
