flex 6500 and spe2k
on5poon5po Member ✭✭
  • on5poon5po Member ✭✭
    edited May 2018
    Hello everyone,
    After the discussion on the cable DB15 / USB, I ask myself the question, to know if the USB ports of my 6500, are active, since, I am still under win7 with my I7
      flex version 1.9.13.89, I tried version 1.10.12 and 1.10.15, did not work, and everything works fine,
    My question is the cable Db15 / USB connection spe / flex, will it work, the USB port of my flex 6500, does it work ??
    I can not find the USB port in the setting, does not seem to support before version 1.10 ??
    is there a solution, without having to change pc and pass under win 10
    thank you for answering me
    73 on5po, Janny
  • RiaRia Member ✭✭
    edited November 2019
    USB cable is not supported in version 1.9. It is only in 1.10 and above. And of course it works with all 2.x versions
    This is the wiring for the cable:
    (USB) --------> (Amp CAT A)
    Pin 2 (RXD) ------------------> Pin 9 (TXD)
    Pin 3 (TXD) ------------------> Pin 1 (RXD)
    Pin 5 (Ground) ------------------> Pin 4 (Ground)
    This is the configuration under settings -> USB cables
    This is two cables. You can set up only one:
    Make sure baud rate matches the amp.
    Set CAT to FLEX or Kenwood on the amp. The difference is that when using FLEX you need to set the power from the amp front panel using arrow keys. You must do this for every power level (low/mid/max) and band.
    edited June 11
    Hello, Ria,
    Thank you for your answer, but is there a solution with Win 7, since there is only version 1.9 that works with my pc?
  • KY6LA_HowardKY6LA_Howard La Jolla, CA. Paris and Sablet FranceMember ✭✭✭
    edited May 2018
    Bonjour Janny Tout versions de SSDR Marche tres bien sur mon ordinateur W7. vous n'avez pas besoin W10
  • David Decoons, wo2xDavid Decoons, wo2x Member ✭✭✭
    edited May 2018
    edited May 2018
    Merci Howard,
    J'ai essayé les version 1.10, chez moi, problemes ,J'ai porté mon PC pour faire placer W10, et j’achèterais également la version 2 de flex ,
    Merci Bon séjour en Europe
