A - B slice tuning knob detent
Dave
Dave Member ✭✭
edited November 2018 in FLEX-6000 Signature Series
No detent to menu on A-B slice tuning knob  - 2.2.8, 6600m. Read the manual and cannot find any menu setting to turn it on. Should it be on as standard ?
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited May 2018
    Not sure what you mean by detent. Push in on either slice A or B knob and the menu comes up for the receive functions.
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    The b tuning knob and push menu only work when a second slice is active the a works when only 1 slice is active as long as its set as slice 1.
  • Dave
    Dave Member ✭✭
    Thank you for the reply, both are not working. I was thinking I have missed a menu to turn on the push for menu.
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited May 2018
    Dave, are you running the radio as stand alone or do you have it connected to a computer via the Lan connection?
  • Dave
    Dave Member ✭✭
    edited May 2018
    Stand alone
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited May 2018
    Dave, when you push in the the VFO A knob that is where the receive menu is. Same on VFO B when that slice is active. Have you tried pushing in on the VFO A knob? Email me k2dlz at yahoo dot com
  • Dave
    Dave Member ✭✭
    edited May 2018
    Hi Rick, I have tried pushing in the VFO A and VFO B when B slice is open, it has no response. I have tried pushing it in and holding for 5 seconds but both have no response.
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited May 2018
    Dave, if you get no response from the VFO knobs you might want to open a help desk ticket.
    https://www.youtube.com/watch?v=r8nk7K3gjGo
