Flag Split Mode
Al Reeves
Now running Ver 2.2.8 on my 6300. Love the new Flag Split Mode. When I activate "Split" Slice B sets up 0.5 KC above Slice A. Is there a way to modify the 0.5KC value? For instance 1KC or 2KC? Thanks to Flex's software team. Nice job! Easy install and no problems with running 3rd party programs.
There is no way to modify it, sadly. Just enable the split and move the slice once it appears.0
The Split is 5KHz up. After you create it you can move it to another frequency.0
Here the SPLIT button creates the B slice "up 1" -- see snapshot.
Only tried in CW mode (that is all I use).
Is the split amount different depending on mode, radio model, or something else?
Al / NN4ZZ
al (at) nn4zz (dot) com
6700 & SSDR-W V 2.2.8
Win10
Yes, it is 1 kHz on CW, 5 kHz on SSB. Nice!
73,Craig, KØCF
Nice defaults, but how hard would it be to include a menu item to change that value?0
I do not do much split operation BUT that makes this Split Mode function even more valuable since I don't have to stop and expend brain cell activity to remember how to manually set it up hihi Anyhow, I for one like this feature.
---Gary WB8ROL1 -
Mode.
Probably more difficult than you would expect. In any event, whatever the split offset is, it is only a starting point. When a DX station says "up 5", the pile-up might start 5kHz above the DX station, but will spread out from there. The defaults are good starting points.
The neat thing about the panadapter as implemented by Flex is the ability to "seee" the less crowded spoys in th epile-up & go there, or, more importantly, be able to "see" where in th epile-up the DX statioon is listening & move your TX frequency accordingly. I have busted many pile-ups by setting my TX frequency to just above (or below) the station the DX station is currently working.
-- 73, Ray, K9DUR
Gary,
As a somewhat more than casual DX'er, I simply LOVE this new feature.
-- 73, Ray, K9DUR
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
