6600M - will not transmit on FT8
Allan
Need help. FT8 decodes fine on 6600M , get tones through radio speaker on transmit but no output power. Have read through the help suggestions, but have been unable to solve the problem. Everything working fine on other modes including RTTY with N1MM.
Check the AUDIO setting in the amsettibgs menu in WSJT0
If you're using WSJT-X, then here's what worked for me in these screenshots.
I set CAT Control / Network Server to localhost:5001, because that's where my SmartSDR CAT TCP port is configured for Slice A. Notice that my COM5 in SmartSDR CAT is set to "P" for PTT and the PTT Method is set to RTS, as is my SmartSDR PTT port. Also, ensure your DAX Audio TX is set in the Audio tab, as shown in the second screenshot.
Then press the "Test CAT" button and ensure it's working, followed by "Test PTT". It should key the radio PTT if you have it configured correctly.
Hope that's helpful.
Rick, W5FCX
I have had the same issue and discovered the first time that the DAX button on the SmartSDR sidebar was not enabled. The second time it happened, the TX button in the DAX control panel was not enabled, so it can be a variety of things. 73, Paul W0AD
Also note that if you're using multiple computers with your Flex, you'll have to re-enable the "TX Stream" in DAX when switching between computers.0
You didn't say so I'll ask - does that radio switch into the transmit mode (is the PTT working)?
If so I might suggest checking to see if you have some narrow values in the high and low cuts in the microphone panel. I had this bite me a time or two while experimenting. Open the cuts up (like from 50 to 3000 Hz). While trying to get things set up for RTTY I had this happen and it took me a few minutes to figure out I had the cuts set to one place and the tones were somewhere else. Everything looked like it was working but there was no RF output.
Good luck
K5XH
Thank you K5XH. You solved my problem. 73, Allan
Glad I could help!
73 Mark
2
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
