SmartSDR CAT no radios available
Is the radio making it through the firewall? Check your router to see if the radio is there, then check Windows defender0
Jon, you didn't say you had found any answers in this forum so may I suggest you try...
https://community.flexradio.com/flexradio/topics/smartsdr-there-are-currently-no-radios-available
Good Luck
By the way, try deleting the ports from the CAT window instead of device manager.
Roy - W5TKZ0 -
Thank you for you replies,
Micheal, the radio is visible and was working well before the win10 update. I rechecked firewall and windows defender anyway with no success.
Roy, I have been looking for a solution in the forum but can ́t find it. The link you sent is about a radio not showing in SmartSDR. This is not the case, I ́m able to use the radio in SmartSDR and DAX is also working. The one not working is SmartSDR CAT, where no CAT ports appearing and no radios appearing at all, only the message "There are currently no radios available".
I think something went wrong during the win10 update, because the old CAT ports are persistent in windows device manager, and I think this is were the problem is, but can ́t find how to delete them.
Here is the situation I find after deleting the virtual ports manually and reinstalling SmarSDR from zero:
As you can see, Flex Old virtual ports appear when SmartSDR CAT is launched at windows startup.
Best regards,
Jon, EA2OT0 -
This issue was resolved via the HelpDesk. A repair of the FlexVSP driver was needed. Probably because removing FlexVSP ports via the Device Manager does not properly remove the associated registry entries. Refer to the SmartSDR CAT User guide for the procedure for resetting the FlexVSP ports.0
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
