My 6300 NO turn On
Sal ( HK1T )
Any help?...
when i try to turn on the 6300, .....Push the power button.. After 50-55 seconds of green flashing my 6300 no turn on, after this time the radios goes off, The factory reset dosent works...
Thanks..
Thanks..
I am converting this to a help desk ticket.0
Many Thanks..!0
Power Supply Voltage?
Adequate current?0 -
Yes, im using a MFJ 25AMP power Suply, and the VHF radio its working fine,whit the same powerS (double Check 13.9 V)
All the cables are disconected (obviusly not the power cord), so sad i receive the radio only 3 monts ago. :-( I did the factory reset, and it's the same result ... When i try to turn ON i receive 50-53 seconds of green flashing and goes to Off.
Thats what mine did when it had its fan issue. Good luck. If you only purchased a a few months ago you should be ok to get it fixed for free.0
Try a factory reset INCLUDING disconnecting power for a few minutes. Good luck & hope it's easily fixed.0
Thanks George,
I did... and its not working. Again when i try to turn ON i receive 50-53 seconds of green flashing and goes to Off.0 -
I hope too, Thanks Delbert.0
- 375 Community Topics
- 105 SmartSDR+
- 427 SmartSDR for Mac
