My 6300 NO turn On
Sal ( HK1T )
Sal ( HK1T ) Member
edited April 2019 in FLEX-6000 Signature Series
Any help?...
when i try to turn on the 6300, .....Push the power button.. After 50-55 seconds of green flashing my 6300 no turn on, after this time the radios goes off,  The factory reset dosent works...
Thanks..
    edited April 2019
    I am converting this to a help desk ticket.
  • Sal ( HK1T )
    Sal ( HK1T ) Member
    edited May 2018
    Many Thanks..!
  • K5CG
    K5CG Member ✭✭
    edited October 2018
    Power Supply Voltage?
    Adequate current?
  • Sal ( HK1T )
    Sal ( HK1T ) Member
    edited May 2018
    Yes, im using a MFJ 25AMP power Suply, and the VHF radio its working fine,whit the same powerS (double Check 13.9 V)
    All the cables are disconected (obviusly not the power cord), so sad i receive the radio only 3 monts ago.  :-(    I did the factory reset, and it's the same result ...  When i try to turn ON  i receive  50-53 seconds of green flashing and goes to Off.
  • Delbert McCord
    Delbert McCord Member ✭✭
    edited May 2018
    Thats what mine did when it had its fan issue. Good luck. If you only purchased a a few months ago you should be ok to get it fixed for free.
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    Try a factory reset INCLUDING disconnecting power for a few minutes. Good luck & hope it's easily fixed.
  • Sal ( HK1T )
    Sal ( HK1T ) Member
    edited May 2018
    Thanks George,
    I did...   and its not working.  Again when i try to turn ON  i receive  50-53 seconds of green flashing and goes to Off.
  • Sal ( HK1T )
    Sal ( HK1T ) Member
    edited May 2018
    I hope too, Thanks Delbert.
