S9+ Noise on all bands in all modes
Paul W5PF
Paul W5PF Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
My radio is the 6600 running SSDR V 2.1.32. This morning the rig was working fine. I left it running and this afternoon I saw a station spotted that I wanted to work. I found that I had S9+ noise on all bands and all modes. Some strong signals were visible on the waterfall. When I disconnected the antenna the signals went away but not the S9+ noise. I have nothing connected to the radio except power and the ether net cable, still have the noise.
I have another radio which works fine with the same antenna with no noise problem.
I have shut down and restarted SSDR and I have rebooted the radio with no change.
Anything else I can try?
Paul W5PF
  • [Deleted User]
    edited April 2020
    Is your WNB on. I had the same problem tonight with my 6300. Turned off WNB and it went away
  • Paul W5PF
    Paul W5PF Member ✭✭
    edited December 2019
    Thanks Steve. Tried that but NB and WNB have no effect on the noise.
  • RoyS
    RoyS Member ✭✭
    edited April 2018
    Paul, was your reboot on the radio a factory or just turn off and on? Also ck your power supply. It could have failed.
    Roy - W5TKZ
  • Paul W5PF
    Paul W5PF Member ✭✭
    edited April 2018
    Thanks Roy,
    I have not done a factory reset, just shut down radio and turn off power and then restart.
    The power supply is good.
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited April 2018
    If a factory reset does not resolve the issue, then I think you need to open a help desk ticket..
    ( I had the same problem ).
    Al, K0VM
  • Tim - W4TME
    edited April 2018
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  Please respond using the HelpDesk ticket for issue resolution.
    If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited February 2020
    Me too but on a 6400M. Did a factory reset (actually several) to get it to clear. Now I have problems with my transmit audio. Not sure if it is related but I think it may be. I have a help desk ticket open already.
  • Paul W5PF
    Paul W5PF Member ✭✭
    edited May 2018
    RIck,
    My radio is back at FLex for repair. They suspect a problem in an SCU.
    Paul W5PF
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited May 2018
    My 6600 is going back to Flex for SCU issue as well.
  • Kurt Zwerger
    Kurt Zwerger Member ✭✭
    Have your problem been resolved?I have a new Flexradio, bout just 1 week ago with the same symptoms.
    Best regards.
