FLDigi stpped working after 1803
Victor Gavron
Following MS upgrade 1803, I lost the audio in my PC, from my Flex6500. So I uninstalled .09 and installed smartsdr 2.1.33. I got my audio back, and I can transmit with my microphone. However, when I try to transmit with FLDigi, the flex screen shows "as if" I am transmitting (waterfall and spectrum go blank, MOX button goes blue), but no RF power goes out of the rig. Also TX stream on the DAX panel does not show any activity. Any advice would be appreciated.
Vic, AA5IR
Vic, AA5IR
Did you follow this official advice on 1803?:
https://community.flexradio.com/flexradio/topics/important-notice-windows-10-update-1803-precautions...
I did. Then
1) FLDigi DID start transmitting.
2) Then I no longer have audio from my PC. So I reinstalled SDR...31 but this time it made no difference.
Any idea how to recover audio through my PC? I have checked the sound settings. I see that on the Playback tab, the audio is going through "Dax reserved audio RX 1" instead of through the speakers, and I don't seem to be able to change that.
Again, help would be appreciated.
I lost all my digital modes after the 1803 update. I did follow all the directions that Tim provided. After a lot of frustration I de-installed and reinstalled DAX with these instructions:
https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
Rebooted and now all digital modes work again.
In the list of audio playback devices, select your PC speaker, select 'set default'
AL, K0VM..0 -
Check DAX Button. on SmartSDR0
All the Reserved audio channels on the PCs playback setting must each be Enabled. And the PC local audio must be set to Default. Not Default Communication. You have to right click on each Reserved channel to make sure they are Enabled. Check Recording Tab also to verify the Reserved channels are Enabled. If the Reserved channel is Default you may have to Disable it first before setting the pc audio channel to Default. Then go back to Enable the Reserved channel. I use a Heil HC6 headset and plug both microphone and earphones into computer directly. I am still on Windows 10 Home 1709 and not in a hurry to upgrade to 1803. 73 Bill W9JJB0
After going twice through the instructions, I still didn't have audio. Neal, K3NC, a support engineer worked for an hour on my system, and got it going. Thank you Neal and Flexradio for this support.0
That’s good news Victor. Can you (or Neal) provide any lessons learned from your experience to get things back up and running? It would be good to document your insights here in this thread if you can. Thanks!0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 765 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 812 Third-Party Software
