W10 1803 Update 4/30/18
Jim KJ7S
A bit of a problem, but not unexpected.
Here's what I did:
Uninstalled two previous versions of SSDR, .30 and .32 (using IOBit Uninstaller).
dwnlded and installed W10/1803. upon restart, received the expected (sort of) error with DAX.
I then re-installed .33 over the existing .33 still in the machine, with the radio off. Restarted machine agn., and all returned to normal, with the exception that I had to "re-aim" the external program(s) to the proper sound devices (WSJT-X, etc). Everything seemed to settle down after the relatively minor inconveniences.
Here's what I did:
yes i force the update but on them big update i fine if you uninstall the flex software do the update then reinstall no problems
Can you send me a link to IO bit uninstaller?0
google is your friend.
I forced the 1803 update this afternoon too. I did a really sloppy clean removal of SmartSDR, and suffered some DAX issues after reinstalling SmartSDR, Don't get sloppy, do a clean removal of SmartSDR, maybe even polish things after the removal and you will probably have no DAX issues. SmartCAT problems were non-existant.
Before the removal it might help, if you deselect any DAX selections in SmartSDR, and in the DAX Control Panel, then add the selections back after you successfully reinstall SmartSDR. Other than the operator glitches this update was no more difficult than the other Win10 updates.73, Jay - NO5J
I just saw Tim's alert on the pending 1803 update. I wish I saw this last night. This morning I just loaded the latest Flex version on a new PC I'm using with my Flex 6500. Fresh install of Win 10 PRO that shows ver 1709. Assuming Tim is listening, I'm assuming I should uninstall the current version according to the last part of his procedure. Question 1, is the Windows uninstall sufficient, or should I use Revo? Next, request the 1803 update, say a prayer and pull the trigger. Reinstall the latest version, hope and pray!
Cnet.com and IOBit.com for the uninstaller
http://download.cnet.com/IObit-Uninstaller/3000-2096_4-75161625.html
https://www.iobit.com/en/advanceduninstaller.php
If DAX is working properly, uninstalling Windows with removing DAX on the last and latest install should be fine. Uninstallers like Revo are only needed after DAX is hosed up and the uninstaller fails.0
Question - if you are running 1709 and have your update settings configured to let you to delay 1803 for a long time ( e.g. SIX MONTHS, a year, etc ), what is the downside of just not installing 1803? Or asked another way, if you are not interested in the new features in 1803, why install it now? Is it reasonable to think that another update may become available that doesn’t impact DAX. Regards, Al / NN4ZZ0
True that Tim and thanks for the reminders of complete uninstall/restart/install. I generally use IOBit stuff to take care of a lot of the 'maintenance' on the machine as it seems to do a good job and doesn't need a whole bag of 'Computer Science Cookies' to get it done hihi. The last time I did a complete uninstall, including the manual 'RegEdit', was a pain I don't care to repeat too often.0
This is a good question. The answer probably has to do with stability. Some people wait for a few months to let the more grievous of defects get fixed before jumping ship. Others are fearless and jump into the muddy water without knowing how deep the water really is ;-)
I, on the other hand, have no choice. My work/test machine will be upgraded later this week to support the new OS level.0 -
And there is the reason we will not publish a procedure that requires Windows "brain surgery" with a hatchet (Regedit). It's just too easy to mess up and make your OS comatose.0
I know that Tim prefers the manual uninstall procedures, and I have no experience with IOBit, but I presume it's a lot like RevoPro, which I've been using for at least 2-3 years to do full, clean, uninstalls...not only of SSDR, but many other programs I've tried out and decide to part with. It seems to keep the registry clean and re Imoves all traces of whatever it's sicced' on, as long as you use the 'Advanced Scan' feature. Like IOBit, it doesn't require much in the way of advanced computer knowledge. At the moment, I'm letting 1803 download on this laptop, after cleaning off SSDR. I did the same on the main shack desktop after getting the expected DAX error on the first attempt. That one is working fine, at least for now.
Tim DAX is working fine under 1709. You stated, " uninstalling Windows with removing DAX on the last and latest install should be fine." I presume you mean uninstalling using the Windows uninstaller ... right? Since it's a new clean install. I'm thinking to install by backup (before the Flex install) , see if I can get 1803, than install the Flex software directly into 1803. That should eliminate the possibility of problems related to the update process.
So Jay, to save some time would you say that an uninstall of Flex software, using iObot is thorough enough? Has anyone ever compared its uninstall to the manual one?
I haven't compared, mine are always manual clean reinstalls, using the procedure described in the article on the Zen Desk. Do them often enough, and they don't take very long. I usually only go to that much trouble only after an update breaks things.
Do It sloppy, like I did today, and they take a little longer.73, Jay - NO5J
It should have read...
If DAX is working properly, uninstalling all versions of SmartSDR and removing DAX on the last and latest install should be fine. Uninstallers like Revo are only needed after DAX is hosed up and the uninstaller fails.
I followed Tim instructions, let Win 10 upgrade do its thing, reinstalled Flex .33 and all is fine. Only thing I had to do was reassign the Dax Audio RX 1 and Dax Audio TX for my Rtty Soundcard choices. Smooth as silk upgrade.
I have nothing uninstalled before i start the W10 update. I only close before update DAX and CAT.
After W10 update i fire up SSDR - not any problem. Nothing to reinstall here.
73 Chris
DL5NAM0 -
Chris, you are right.
The problem with SSDR vs W10 updates has always been to do with the fact that DAX and CAT get left active and running during the update process.
Simple fix: create yourself a quick batch file that terminates DAX and CAT processes as part of your normal close down routine. That way DAX and CAT are never left hanging. I did the opposite for start-up as well, as often I don't want them auto-starting for no good reason.
ps. no problem at all with PSDR vs W10-1803, been running it for about a month now.2 -
This was very GOOD information. I updated all my Windows 10 computers last night to W10 1803... Took about an hour!! However I do not have any SSDR software or DAX loaded as I do not have a Flex 6600M yet,, but that ALL CHANGES on Wednesday when the UPS driver rings my doorbell to drop it off!!! :-)
CQ,CQ,, WA6PHN,, Can You Hear Me Now!!! :-)
So the logical Microsoft progression will be to follow 1803 with numerous fixes to problems we users submit, or should I say discover for Microsoft. After installing 1803, just curious how many will suspend any subsequent updates for as long as possible?
Same here. Updated last night in anticipation of Wednesday's 6600 delivery.
So if we both turn on our 6600 radios on Wednesday, will the Earth Shift on its Axis by 3 deg due to the EMP being generated from our ham shacks???? :-)0
OK, I followed the advice of one of the above posters, I made sure DAX and CAT were turned off, that is shut down. I did NOT remove anything. Forced the WIN 10 1803 update, all went well, no issues at all, phew.
Peter
W2PP0 -
Tim.....I'm lazy. I've blocked the update for now. Rather than go thru the uninstall process that you've described is there any sense in just sitting tight at my current windows version on the assumption that there will be an SSDR update that mitigates this problem?
73....Frank
I agree I hated that DAX and CAT were always running and have always removed them from startup after every install. I use a bat file to start them and SSDR when needed. I only once had a problem with updates which was when updates occurred while DAX was loaded. Now I am more careful.0
I've had Windows update issues with DAX and Cat turned off.0
This behavior will change in SmartSDR v2.2. SmartSDR will start DAX and CAT when it is loaded and will shut them down when SmartSDR is shut down. You can change this behavior too. However, if you want to have DAX and CAT run at boot time, you will have to create your own shortcuts and place them in the startup folder1 -
Finally!
but for the sake of others, what about the guys on v1.x do they have to live with this culpable design mistake or will the change be bug-fixed in v1.x also?1 -
Im hoping this new feature will be also in the Maestro, as I havent used SmartSDR for a while, prefer the Maestro
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 724 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 944 Third-Party Software
