6600 FROZEN TX PWR SETTING
Ian Snow
Newbie here. Setting up Winlink Express in WINMOR mode I set the TX pwr on my 6600 at 40w. Now ithe max pwr I can set on any band/mode is 40w. How do I return the setting to normal? SmartSDR Ver 2
Ian VA3QT
Ian VA3QT
This one of my port peeves.... go to the radio set up screen and reset the power then reboot and when the radio reappears it will be what you set it to.... excuse that preposition0
That worked, tnx. 73, Ian VA3QT0
No, it is not normal. And rebooting is also not necessary. What you probably did not do is hit the Enter or Tab key after entering the max power value. If you just enter the value in without hitting either of those keys, the value does not get set. All fields where manual entry is required in the Setup window, require hitting the Enter or Tab key after the text or number is entered.
I just retested entering a value for max power and I set it to 5 different values and it was set properly each time.0
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
