heil proset elite headset adapter for 6400M
Looking for the adapter that will allow me to use my Heil Proset Elite headset with the 6400M.  The plugs on the end of the cable is 1/8 inch plugs.  Gray one has 1 ring and the black one has two.  Do these plug right into the 6400M.  i.e. mic and speakers.
Welcome!
  • Member ✭✭
    edited June 2018
    If it has the hc6 element like my proset has it plugs in direct and works fine but no mic bias used.+20db on. My gain is set around 60.
  • Member ✭✭
    edited September 2018
    Be sure to get the mic plug in the mic jack and the phone plug in the phones jack.
  • Member ✭✭
    edited June 2018
    It cannot be the proset elite ic that is for icom and will not work without an adapter
  • Member ✭✭
    edited April 2018
    OK which one is which.  I """""THINK""""" the black one is the mike????????
  • Member ✭✭
    edited June 2018
    The 1/8" mono plug is the microphone plug.
  • Member ✭✭
    edited April 2018
    Thanks Wayne.
  • Member ✭✭
    edited April 2018
    The gray one is the mike and the black one is the phones.   Seems to do very well but tried for about an hour yesterday.  40 meters was crazy. No one stateside on 20 meters, one very weak station on 17.  will try it on the net this morning.
  • Member ✭✭
    edited April 2018
    The guys said it sounded good on the net this morning.  40 meters was in bad shape.  Seems to drive the flex a little harder with the same mic gain setting.
  • edited September 2018
    What is used to key radio?
  • Member ✭✭
    Foot switch John.   I think.  Notice what I said.  Combinations from 5 months ago aren't registering right now, I think it is a afoot switch.
  • Member ✭✭
    I read all this but still i have the question about the Heil Pro 7 headset for Icom (blue headset) and want to know what is needed to be able to use it on my soon to arrive FLEX … i don’t have the radio yet to see, so am asking if anyone used this combo?
