Smartlink does not see my Flex6700 anymore
WA6FXT Mike
Smartlink (SSDR v2.1.3x) does not see my Flex6700 anymore. It's been awhile, but I tried SmartSDR remote and could not see my radio. I was also having trouble logging in via my Google account.
I would log in, and would would see my name and call on the startup screen; but, no radio.
Created a Flex Smartlink account would get to the same place
Upgraded to v2.1.33, same results.
All this time my iPad SmartSDR works both ways, local and remote and my laptop (Win7 Ultimate) works fine locally.
Any ideas?
Any ideas?
Hi Mike,
Not an expert here but I believe the account you registered under initially into SmartLink is also somehow connected to your radio via serial number.
If your account is messed up or you had to create a new one, it could be part of the issue with why SmartLink doesn't see it.
Another possiblity is that you may have to re-register your radio. I recently got a 6600 which came with 2.x smartlink. But before I could see it remote I had to go through the radio registration process and it took a few steps. You might need to redo that.
Mark0 -
from the LAN and you see the Radio?
If so click on the "SmartLink setup" and then "Unregister" the Radio and then re-register it.
hope this gets you going.
Bret
WX7Y
Make sure under network settings that the "test" bar gives you the green light. If not, try resetting your router.0
And make sure the IP of the radio is the same as it was before the update if not then redo your Router's Firewall settings
Bret0 -
I’ve gone through the registration several times. Each time succeeds0
I’ve done that several times0
All, remember the iOS version works great, both remote and local. But, THANK YOU all for the suggestions and keep them coming. Mike0
Mike,
that happened to me from the original download. for some reason the file was incomplete. i did uninstall the original download and reloaded it. i seems to work fine now.
hope this helps.
Bud N4RJR
@Mike WA6FXT
Likely worth opening a HelpDesk Ticket to have FRS look into your SmartLink configuration(s).
In summary I have taken away that you have this condition:- All running SmartSDR 2.1.33 (radio and Windows) and latest version for iOS
- In the startup after not using remote for awhile, software was updated at least at the SmartSDR for Windows level. Not described was whether you are able to operate locally after upgrades.
- In the startup after not using remote for awhile, you had difficultly with the Google Log-In for SmartSDR. You'd mentioned a "create" aspect with SmartLink, but uncertain if the credentials in SmartSDR for iOS had to be updated in the recent process.
- Radio via LAN (locally) with SmartSDR for iOS - works fine
- Radio via WAN/SmartLink (remotely) with SmartSDR for iOS - works fine
- Radio via LAN (locally) with SmartSDR for Windows - works fine
- Radio via WAN/SmartLink (remotely) with SmartSDR for Windows - is the only place with NO JOY
- Confirm that the radio and the Windows SmartSDR are all on the latest version (2.1.33 onwards.)
- Locally when accessing the radio with Windows SmartSDR at the radio chooser window (when you get started) make sure everything is activated for the SAME SmartSDR account. You most likely will see your radio twice (one local and once via SmartSDR) at some point.
- Confirm that from the radio SmartSDR does a "green" diagnostic when you test it
- And give it a whirl
The Google sign-in to SmartLink seems the least robust validation option, and if anything in your system is running 2.1.32 or earlier the system is likely broken. FRS can give you details, and I think they posted an explanation here on the Community Boards, but basically the Google sign-in process validation was broken by a Google change which then led to the release of 2.1.33 as the fix. In the process of fixing the Google issues the legacy abilities for pre-2.1.33 versions to log in via Google appeared to have disappeared. Uncertain if a pre-2.1.33 existing Log-In to SmartLink will remain viable while "kept alive" but seems that you can't get back in using the Google log-in validation unless you run 2.1.33 onwards.
Steve
K9ZW0 -
I had the same exact problem..per suggestion from Flex I rebooted powered down my cable modem and router and now it works.0
Ok! Issue MUST be with my laptop or OS. Tried v2.1.33 with my W10 Laptop and BOTH work great!
Now, it’s time to dig into my primary Laptop and figure what happened.
Thanks to ALL who gave me the various ideas to try. You’re a great resource.
(Now to figure out how to mark this solved)
73’s de Mike WA6FXT0 -
Or your Router could be at fault, If your router isolates the wireless from the Wired LAN devices would cause this and may just be a setting in your router.
73's
Bret
WX7Y
Both laptops are wireless and have been tested on multiple networks. Good idea, though.0
Make sure that if you have a firewall or Internet security suite that it isn't blocking access to your radio over SmartLink. Disable them temporarily to test.0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 223 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
