Flex 6600 Diversity RX Problem
Cal N3CAL
My Flex 6600 works fine with a single slice using Ant-1 or RX-A. The noise floor is down around -125 (picture 1 is RX-A and picture 2 is Ant-1). When I select Diversity the second slice comes up with Ant 1 on slice B and RX-A on slice D (picture 3) but the displayed noise floor jumps up to around -80 and the signal drops away??? Picture 4 shows slice A and slice D where noise floor is ok around -120 with same antennas. I'm currently running remote so I haven't tried a factory reset yet. Cal/N3CAL
Single Slice RX-A (Picture 1)
Single Slice ANT 1 (Picture 2)
Diversity 2 slices An1 + RX-A (Picture 3)
Diversity 2 slices reversed RX-A + ANT 1 (Picture 4)
That is incredible to me that you would have a -125 dBm noise floor on 75 meters! That is just about the noise floor of the radio itself!
Is Loop A enabled?0
Antenna 1 is a 80m Double Bazooka (Inverted V). RX-A is a Pixel Magnetic loop RX. and RF gain was set at 0.
Cal/N3CAL
Salvador, unlike my previous Flex 6500 I don't see "Loop A" as a selection on the 6600?? Where is it supposed to be?
Cal/N3CAL
The "Loop" option is not part of the 6600.0
My bad, I thought it had it. Have you tried putting the mag loop on rxB instead and then try Ant1 + RxB for DIV?0
Good news! I just got back home and did a full reset and the problem is gone! I really have been enjoying the 6600!
I wonder if there could be a way in future SSDR releases to somehow initiate a full reset remotely? That would be a desirable feature to me.
Thanks to all for your replies.
Cal/N3CAL0 -
Well, good news then. Enjoy the radio Cal!0
Glad it was easily resolved. I'll be moving with in the year and should have a little room for antennas. I'm looking forward to separate receive antenna(s) so this thread caught my eye!
Agree on reset when remote ops, hey, it's a computer!
Jim0 -
Ya I don't do 80 much even though I have an 80m loop antenna (280 feet of wire). On a really GOOD day my noise floor is 105 on 80.
This is in a nice neighborhood with buried power, all cable and utilities underground. It is just a noisy band for me.0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
