Flex 6600 Diversity RX Problem
Cal  N3CAL
Cal N3CAL Member ✭✭
edited December 2019 in SmartSDR for Windows
My Flex 6600 works fine with a single slice using Ant-1 or RX-A.  The noise floor is down around -125 (picture 1 is RX-A and picture 2 is Ant-1).   When I select Diversity the second slice comes up with Ant 1 on slice B and RX-A on slice D (picture 3) but the displayed noise floor jumps up to around -80 and the signal drops away???  Picture 4 shows slice A and slice D where noise floor is ok around -120 with same antennas.   I'm currently running remote so I haven't tried a factory reset yet.  Cal/N3CAL
   Single Slice RX-A (Picture 1)
Single Slice ANT 1 (Picture 2)
Diversity  2 slices An1 + RX-A (Picture 3)
Diversity 2 slices reversed RX-A + ANT 1 (Picture 4)
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited April 2018
    That is incredible to me that you would have a -125 dBm noise floor on 75 meters! That is just about the noise floor of the radio itself!
  • EA4GLI
    EA4GLI Member ✭✭✭
    Is Loop A enabled?
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited April 2018
    Antenna 1 is a 80m Double Bazooka (Inverted V).  RX-A is a Pixel Magnetic loop RX.  and RF gain was set at 0.
    Cal/N3CAL
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited April 2018
    Salvador,  unlike my previous Flex 6500 I don't see "Loop A" as a selection on the 6600??    Where is it supposed to be?
    Cal/N3CAL
  • NX6D Dave
    NX6D Dave Member ✭✭
    edited April 2018
    The "Loop" option is not part of the 6600.
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited April 2018
    My bad, I thought it had it. Have you tried putting the mag loop on rxB instead and then try Ant1 + RxB for DIV?
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited April 2018
    Good news!  I just got back home and did a full reset and the problem is gone!   I really have been enjoying the 6600!
    I wonder if there could be a way in future SSDR releases to somehow initiate a full reset remotely?  That would be a desirable feature to me.
    Thanks to all for your replies.
    Cal/N3CAL
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited April 2018
    Well, good news then. Enjoy the radio Cal!
  • Jim Osterling
    Jim Osterling Member ✭✭
    edited April 2018
    Glad it was easily resolved. I'll be moving with in the year and should have a little room for antennas. I'm looking forward to separate receive antenna(s) so this thread caught my eye!
    Agree on reset when remote ops, hey, it's a computer!
    Jim
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited April 2018
    Ya I don't do 80 much even though I have an 80m loop antenna (280 feet of wire).  On a really GOOD day my noise floor is 105 on 80.
    This is in a nice neighborhood with buried power, all cable and utilities underground.  It is just a noisy band for me.
