FT8 Mode
jim
jim Member ✭✭
edited March 2020 in FLEX-6000 Signature Series
In FT8 mode when going to xmit, slice freq goes from 14074 to 14073.5..
Freq in FT8 panel also shows 14073.5 in xmit.  I am able to make contacts but
don't know why freq is shifting.  Any ideas.  Just started doing this.  Work normal
before.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited April 2018
    X/RIt enabled?
  • AH0U
    AH0U Member
    edited June 2019
    You probably have your software set to “fake it”. In check this
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    This is normal and expected behavior. The application adjusts your dial frequency to keep your tones centred in the rig’s audio passband. Not as big a deal for Flex rigs, but some conventional SSB transmitters have more restrictive audio characteristics.
  • Ria
    Ria Member ✭✭✭
    edited March 2020
    It's in section 4.2 of the WSJT-X user guide:
    http://www.physics.princeton.edu/pulsar/K1JT/wsjtx-doc/wsjtx-main-1.7.1-devel.html
    • Split Operation: Significant advantages result from using Split mode (separate VFOs for Rx and Tx) if your radio supports it. If it does not, WSJT-X can emulate such behavior. Either method will result in a cleaner transmitted signal, by keeping the Tx audio always in the range 1500 to 2000 Hz so that audio harmonics cannot pass through the Tx sideband filter. Select Rig to use the radio’s Split mode, or Fake It to have WSJT-X adjust the VFO frequency as needed, when T/R switching occurs. Choose None if you do not wish to use split operation.
  • jim
    jim Member ✭✭
    edited April 2018
    Thanks for the help.  Turns out the the ft8 was in the *fake" mode.
    I have no idea how it got change.  Seems to be working fine now.
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited April 2018
    Well it was working fine with fake it too.  Just different. Either is fine.
