A/D converters are hanging up then starting again on my 6700. The waterfall show a horozontal black
edited April 2019 in SmartSDR for Windows
The sampling period seems to be interrupted on my 6700. Sampling seems to start and stop on a continuous random basis. The attached screenshot clearly show a horizontal black ****  where the data is missing, but the clock keeps the waterfall advancing. Anyone have any ideas about this. Guess I will check Tech Support in the morning. This started a few days ago and is getting worse. Both SCU's are skipping (ANT 1 & ANT 2).
Welcome!
  • Member ✭✭✭
    edited April 2018
    Are you sure it is not network drops?   I see that same behavior when something causes a collision on the network.
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited April 2019
    Hi Al
    That does look like network drop outs.  Is that computer Wifi connected or wired?   Can you share some more details.
  • Member ✭✭
    edited April 2018
    I would certainly do a processor reset.
  • Administrator, FlexRadio Employee admin
    edited April 2018
    First off, your assumption that the ADC is hanging in incorrect based on the screenshot you provided.
    What you are experiencing is most likely a network problem where packets are being dropped because your Network Health Indicator is RED.
    So to start addressing this problem, you need to describe in detail how your radio is communicating to SmartSDR-Win as it applies to your LAN.
