alpha 78 keying, ok with Flex?
K5ROX
K5ROX Member ✭✭
edited April 2018 in FLEX-6000 Signature Series
Alpha 78 keyed with flex, do I need a buffer, I cant find voltage or current draw on relay of amp, schematics only say 24v reed relay.
I feel its safe because the relay connection goes thru transistors used as electronic switches so I'm sure the voltage and current is very low at the jack but its my new flex so not talking any risk.
  • Tim - W4TME
    edited April 2018
    It is a best practice to use a keying buffer as added insurance that you will not inadvertently damage the keying transistors in the radio.
