Lost receive audio on pc with flex-6600
Wayne Michael
No audio. This happened several times over my first week and reboot usually helps but this time even a power down and power back up has not corrected it. Surface pro 2. I reinstalled and no change. Anyone else suffer this?
When connecting via iPad I do get audio and on the PC I get audio through the PC speaker but I am not getting audio to wsjt-x or dm700. I am guessing this related to the Dax application and it is showing a audio stream and on but nothing is going to other applications. I am going to try another PC. Perhaps I’ve corrupted something on my surface pro.0
If you haven't tried another channel yet i would give that a go to see if you see same behavior on all 4 DAX channels?
I have experienced the monitor and side tones disappearing from my Maestro . Toggling usually gets them back, sometimes I have to turn my Maestro off/on. The Maestro just did some sort of update when I powered it up this morning maybe they fixed it.0
A couple things, What version of SmartSDR are you using ?
Is this DAX audio issues?
Are you using a set of Powered speakers and do you have them plugged into the back of the radio or are you using the speakers plugged into a PC?
LOTS of variables?
Make sure in the upper right corner of the screen look at the little speaker ICON and make sure it is not muted.
73's
Bret
WX7Y
This hasn't happened since the last updates.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
