Lost receive audio on pc with flex-6600
No audio. This happened several times over my first week and reboot usually helps but this time even a power down and power back up has not corrected it. Surface pro 2. I reinstalled and no change. Anyone else suffer this?
  • Wayne Michael
    Wayne Michael Member
    edited April 2018
    When connecting via iPad I do get audio and on the PC I get audio through the PC speaker but I am not getting audio to wsjt-x or dm700. I am guessing this related to the Dax application and it is showing a audio stream and on but nothing is going to other applications. I am going to try another PC. Perhaps I’ve corrupted something on my surface pro.
  • KS0CW
    KS0CW Member ✭✭
    edited April 2018
    If you haven't tried another channel yet i would give that a go to see if you see same behavior on all 4 DAX channels?
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited June 2018
    I have experienced the monitor and side tones disappearing from my Maestro . Toggling usually gets them back, sometimes I have to turn my Maestro off/on. The Maestro just did some sort of update when I powered it up this morning maybe they fixed it.
  • WX7Y
    WX7Y Member ✭✭✭✭
    A couple things, What version of SmartSDR are you using ?
    Is this DAX audio issues?
    Are you using a set of Powered speakers and do you have them plugged into the back of the radio or are you using the speakers plugged into a PC?
    LOTS of variables?
    Make sure in the upper right corner of the screen look at the little speaker ICON and make sure it is not muted.
    73's
    Bret
    WX7Y
  • Wayne Michael
    edited June 2018
    This hasn't happened since the last updates.
