FLEX-6500 will not receive.
Ken Howard
No traffic is seen in waterfall. I do hear noise. Antenna works okay on a Icom-7100. I am a new user. This Flex-6500 worked okay prior to antenna change. New antenna tunes okay.
Usually when that happens to me, I have inadvertently selected another antenna or transporter port for receive. Check there first.
If that doesn't work, switch your antenna to another port and try there.
Switching between ant1/ant2, what does it do?
If you get nothing on ant1 or ant2, I would suggest a helpdesk ticket as your radio may need to be returned for repair... but try both ports first.
Switching ant1/ant2, no difference.
Neg. results.
should then follow Ria's advice,helpdesk...0
Another quick check - make sure you don't have "Loop" selected on either of the ANT1 or ANT2 selections.0
Check.
Sorry to be the bearer of bad news then:
https://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Sup...
Open a ticket and they'll get back to you.0 -
I would do a factory reset to make sure there isn't a setting that is causing a problem. You press and hold the OK button while powering on the radio. After the front panel display counts down to 0 and the power LED turns white, release the OJ button.
Then try using the RX-A port and select it as the RX antenna.2 -
This is a real stab in the dark - but one time I was wondering why my radio wasan't working. I fooled around for a half hour before I figured out I was connected to my dummy load. Yikes!0
I can see where that could occur for sure, but not it. Thanks for your response.
Thank you. This has been done to no avail.
Have not tried the RX-A port. Will have to research this. The radio is at the E. O. C. in my county and I volunteer there, so I will try this asap. Thanks.
Tim it is not transmitting either.
This issue ended up being a hardware problem that was triaged and handled by the HelpDesk as an RMA to service.1
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
