Flex 6600+Maestro hangs in TX
Hello All,Just a reflection on a problem I'm currently having...
I'm currently testing the 6600 with a Maestro at my uncles QTH in NC both Maestro and radio is connected to the Router LAN ports. We have a problem that sometimes when running 20 meters with an ACOM2000A some HF seems to find its way to the router. After a while something happens with the connection between the radio and the Maestro and it hangs in TX. A restart of both Maestro and the Flex 6600 is required to get it to work again.
I understand this is a problem for us to fix but it would be preferable it did not hang in TX when this happens.
I don't know if the same happens if I pull the network cable during transmission - but I will try that later.
Tore / SM0NCS
