Slice window offset from frequency
Michael Wheatley
Michael Wheatley Member ✭✭
On one band, the slice frequency (the blue shaded area) offset by 1KHz from the tuning frequency (see attached).  How can I correct this?
Michaelimage
  • AH0U
    AH0U Member
    edited June 2019
    In your side bar right below the bandwidth buttons there is a graph of the bandwidth click and drag it to the place you want it... you have the filter offset
  • Michael Wheatley
    edited June 2019
    Thank you!!
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited September 2018
    You can also put the mouse pointer on the edge of the blue area and it will become a double arrow, and then you can use your mouse to click and drag it to where you want it to be.
