Slice window offset from frequency
Michael Wheatley
On one band, the slice frequency (the blue shaded area) offset by 1KHz from the tuning frequency (see attached). How can I correct this?
Michael
Michael
In your side bar right below the bandwidth buttons there is a graph of the bandwidth click and drag it to the place you want it... you have the filter offset0
Thank you!!
You can also put the mouse pointer on the edge of the blue area and it will become a double arrow, and then you can use your mouse to click and drag it to where you want it to be.
