Remote AC switch
Tim VE6SH
Tim VE6SH Member ✭✭
edited March 2019 in FLEX-6000 Signature Series
Sorry for asking what is likely an obvious question, but I am setting up my remote station and have a question abourt remote switching the power to the Flex. . I had planned on using a Digital Loggers AC switch to remote power on and off the 6600. I take it there is no issue wiring a RCA plug from the open and common terminals to the RCA jack on the 6600 to turn the unit on and off? I believe others are doing this, bui in the back of my mind I seemed to recall a power limit on the jack? 73 Tim VE6SH imageimage
  • Jean Drolet
    Jean Drolet Member ✭✭
    edited March 2018
    there is more simple RCA remote socket at the back allows to turn on and off the Flex6000. Simply touch the tip in the ring and the flex puts it to work to close it again the same thing
  • Jeffrey Kerber, N3VE
    Jeffrey Kerber, N3VE Member ✭✭
    edited September 2018
    Tim, I use the same setup.  This works fine with my IP power ****.  The rca jack must be shorted for the radio to turn on.  Jean has this wrong.
    The jack must be shorted the whole time or the radio will shut off.
  • Jean Drolet
    edited March 2018
    yes it's true you're right you have to hold the tip and ring
  • Tim VE6SH
    Tim VE6SH Member ✭✭
    edited March 2019
    Got it. Thank you both.
  • Matt (K0KB)
    Matt (K0KB) Member ✭✭
    edited October 2018
    This is what I use. I think there are slightly more elegant solutions available now, but this one works for me.
