Remote AC switch
Tim VE6SH
Sorry for asking what is likely an obvious question, but I am setting up my remote station and have a question abourt remote switching the power to the Flex. . I had planned on using a Digital Loggers AC switch to remote power on and off the 6600. I take it there is no issue wiring a RCA plug from the open and common terminals to the RCA jack on the 6600 to turn the unit on and off? I believe others are doing this, bui in the back of my mind I seemed to recall a power limit on the jack? 73 Tim VE6SH
there is more simple RCA remote socket at the back allows to turn on and off the Flex6000. Simply touch the tip in the ring and the flex puts it to work to close it again the same thing0
Tim, I use the same setup. This works fine with my IP power ****. The rca jack must be shorted for the radio to turn on. Jean has this wrong.
The jack must be shorted the whole time or the radio will shut off.
yes it's true you're right you have to hold the tip and ring
Got it. Thank you both.0
This is what I use. I think there are slightly more elegant solutions available now, but this one works for me.0
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
