smart sdrv 2.1.32
Buford, W4HVW
How can I get a copy of 2.1.32? I went online to upgrade my desktop from 2.0.19 but found that 2.1.32 was replaced by 2.1.33. I have 2.1.32 working on my laptop with no trouble. I read where people were having problems with 2.1.33.
Hi Buford
We pulled everything prior to .33 as there was a change in the Smartlink protocol (not our choice) and we needed everyone at .33. Why don't you give it a try. If you downloaded it .32 worked for you and you don't need SmartLink then you can use a version prior to .33.
If you use SmartLink, you need to be at .33 (or higher at some point).
Mike0 -
For me, 2.1.32 was a huge problem partially because it would not stay connected to the radio or via remote connections, and as Michael has stated, a major protocol change upset every smartlink connection, which further forced the update to 2.1.33. For me, 2.1.33 fixed a few major fubars that had me going back to 2.1.30 until .33 finally served the fixes needed. You won't be dissappointed once you get it going.0
The problem is I have my 6300 remoted using smartlink. It is 1200 miles from home.
I can use my laptop but that puts 2 computers on my desk0 -
The challenge is if you are operating remote, there is no way currently to upgrade the radio firmware unless you have a PC on the same LAN as your FLEX-6000 that you can access remotely (such as with TeamViewer) and perform a firmware upgrade. Upgrading a radio remotely does have some inherent challenges. There are times where a software version update may recommend a cold reboot of the radio after the firmware has been updated. This would require the remote operator to have remote control over the radio's power supply and a remote switch to use the REM ON capability of the radio.
We do recognize the desire to be able to update firmware remotely and we have a feature request to provide this capability (#6157)
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
