FRstacks Panadapter Width
W9WLX_Chuck
Hi,
I'm running FRstacks, v2.1.30.8, on a 6600, s/w v2.1.33. I'm trying to use the new feature, Set Panadapter Width. Choosing a width setting does not seem to effect the panadapter. Am I missing something obvious?
-Chuck, W9WLX
-Chuck, W9WLX
OK--I figured it out! I was right clicking on the frequency under the memory tab and choosing Set Width. Choosing from the Active Slice works just fine! Choosing from Memory saves the width in memory.
Chuck
You can also set the standard width you like as Hotkeys. Then when you want to change it is only one key **** away.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
