FRstacks Panadapter Width
W9WLX_Chuck
W9WLX_Chuck Member ✭✭
edited December 2018 in FLEX-6000 Signature Series
Hi,
I'm running FRstacks, v2.1.30.8, on a 6600, s/w v2.1.33.  I'm trying to use the new feature, Set Panadapter Width.  Choosing a width setting does not seem to effect the panadapter.  Am I missing something obvious?
-Chuck, W9WLX
  • W9WLX_Chuck
    OK--I figured it out!  I was right clicking on the frequency under the memory tab and choosing Set Width.  Choosing from the Active Slice works just fine! Choosing from Memory saves the width in memory.
  • John - K3MA
    John - K3MA Member ✭✭
    edited April 2018
    Chuck
    You can also set the standard width you like as Hotkeys.  Then when you want to change it is only one key **** away.
