message says the radio is in use then reboots
KB4OIF
KB4OIF Member ✭✭
During our net this evening, my 6400M had a message come on the screen saying that the radio was in use, try again later.   It rebooted and came back to where I was.  Am running the latest software.  no third party stuff.
«1
  • [Deleted User]
    edited April 2020
    I have had that show up once and a while on my Maestro screen. I usually have to shut maestro down and restart it.
  • Robert Lonn
    Robert Lonn Member ✭✭
    edited March 2018
    OH NO!!! must be Facebook gathering important data!!! :-)
  • KB4OIF
    KB4OIF Member ✭✭
    edited April 2020
    Steve mine did it by itself.  I touch the connect button then run.
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    Almost sounds like RFI was it right after a transmission?
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    First Disconnect from the Power for about 2 or 3 minutes, then if that doesn't work you may have to restore the radio to factory defaults.
    Do you get the same thing from SmartSDR Software?
    let the group know back.
    73's
    Bret
    WX7Y
  • KB4OIF
    KB4OIF Member ✭✭
    edited June 2020
    Hello Bert.  It's working fine.  the guys on the net said it is sounding choice.  It went right back to where it was.  No change in frequency.  Setting are the same.   I do not have smartlink on.  What it seems like is someone is trying to remote into my radio.  Is that possible.
    KB4OIF
    John
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited March 2018
    Not if you are behind a Router and have not registered it on SmartLink or you have a VPN and given others your login's and Passwords for those services I would not think.
    If you monitor the radio with SmartSDR just the search radio window, It will show you if it is being used by another user AND there IP address.
  • [Deleted User]
    edited March 2018
    So did mine. Did it by itself in the middle of a QSO
  • K3SF
    K3SF Member ✭✭✭
    edited March 2018
    i have seen my logging s/w make a connection to my 6600M and then a message pops upon the 6600m main screen about ip client connect.
    the message only stays up for about 3 seconds.
    BUT is has never rebooted the radio...
  • W8QB
    W8QB Member ✭✭
    edited March 2018
    I've had this occur more than once while using the latest firmware: radio powered on, radio goes directly into panadapter view (does not stop at connect screen).  Next, an error message appears on the screen of my 6400M, and moments later the radio inexplicably shuts down the pandadapter and returns to the connect screen.
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    Mine has never done that still running version 2.1.32 all working well.
  • W8QB
    W8QB Member ✭✭
    edited April 2019
    I am using 2.1.33 and did not experience the “self-reboot” issue when running 2.1.32
  • Eric-KE5DTO
    edited December 2019
    Based on what you have described (and you aren't alone, I have seen this report elsewhere), I think what is happening is that the client is getting disconnected from the radio (server).  At this point, the client attempts to reconnect as it sees the radio online.  However, the radio hasn't timed out the original client connection yet and reports that the radio is "in use."
    tl;dr: This is a software issue that we will address.  Currently tracked as #6143.
  • KB4OIF
    KB4OIF Member ✭✭
    edited March 2018
    Thanks Eric.
  • KB4OIF
    KB4OIF Member ✭✭
    edited June 2018
    Just did it again.  Should unhook the Ethernet cable????
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    Still sounds like you have an RF in the shack issue affecting the processor in the 6400M causing the reboot, especially how you described how close your neighbors antennas were. You will probably find if you get the attenuator like Tim recommended this issue would go away. Just a thought.
  • KB4OIF
    KB4OIF Member ✭✭
    edited March 2018
    Wayne it's not RF, I don't think.  The neighbor was not on the air when it did it both times.
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    When it happens is it happening right after or during a transmission you are making?
    If the answer is yes, then most likely it is RF in the shack causing it.
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited March 2018
    I personally think its a bug or something. I had this happen several times and one about the Maestro being disconnected which in my case was the M radio.
  • Tim - W4TME
    edited March 2018
    No, just wait for the radio to time out and try it again
  • Wayne
    Wayne Member ✭✭
    edited March 2018
    And how many qso and net contacts are lost in the meantime ... not really acceptable for a solution.
  • [Deleted User]
    edited April 2020
    Mine was not transmitting. Go out for a half hour or even a day come back in and that is on the display . In my case the panadapter is still receiving under that message
  • KB4OIF
    KB4OIF Member ✭✭
    edited March 2018
    Thanks Tim.   Long as they are tracking it.  Ticket number 6143. What is the harm in disconnecting the Ethernet cable.  I know it gets updates thru that cable.  If a solution is found, would it be sent thru that cable.  It has done it again about 20 minutes ago.  I was not transmitting at the time.
  • KB4OIF
    KB4OIF Member ✭✭
    edited March 2018
    Eric and Tim.  Should I just leave the  Ethernet cable connected.    Please advise.
  • Tim - W4TME
    edited March 2018
    The cable is internal to the radio on the M models.
  • Wayne
    Wayne Member ✭✭
    edited March 2018
    Last time I looked at my 6400M my Ethernet cable connects to the jack on the back of the radio from my router. I disconnect it every time I shutdown to avoid any storm surges etc.
  • Rick  WN2C
    Rick WN2C Member ✭✭
    edited March 2018
    I have had this happen twice to my 6400M. I get a small gray box "The radio selected is in use. Please try connecting again". This is not some one trying to connect to it as it is running stand alone. Using 2.1.30. I haven't upgraded software as I have not connected it to a computer or router yet.
  • Thomas NE7X
    Thomas NE7X Member ✭✭
    edited March 2018
    A very similar issue just happened to my 6400M, ver 2.1.33
    I was changing from 10 to 15 meters and I got an error message that said Maestro error, please reboot. I rebooted and than I got the error, Radio is in use. I rebooted and the system hung. I rebooted again and the radio came back alive. All previous setting were lost.
  • KB4OIF
    KB4OIF Member ✭✭
    edited March 2018
    Mine has done it 5 times in the last 5 days.  Was never during transmit.  always on receive.
  • Doug
    Doug Member ✭✭
    FWIW I would unhook it from the outside world. At least this would eliminate the possibility it is coming from the outside world and not something from RF. Not wanting to rub salt in but FYI I run near legal limit every time I get on the air with 450 ohm ladder line coming directly into the shack a foot or less away from my 6400M and Ethernet cable and never have experienced this with the latest software. I do however have an R.F. choke wrapped around my Ethernet cable and end this choke as close to the cabinet of the radio as possible. I also have a great ground cable hooked to everything in my shack.
