Turning on TNF
Rich McCabe
Member ✭✭✭
This is PROBABLY my imagination, but at one time didn't TNF automatically turn on when you added one?
Seems that anytime you add a TNF you would want it turned on so you can tweak/adjust it. I thought it used to do this but am likely wrong.
Not a huge issue either way.
Look at the bottom left, is it whit or gray?
Terry
It is gray (OFF). But I was thinking previous versions turned it on when you created a TNF. As I said its likely I am mistaken.
Rich, I think it has always been on off selectable. Even back to PSDR you could set one then need to turn it on. Or off1
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
