Turning on TNF
Rich McCabe
Member ✭✭✭
This is PROBABLY my imagination, but at one time didn't TNF automatically turn on when you added one?
Seems that anytime you add a TNF you would want it turned on so you can tweak/adjust it. I thought it used to do this but am likely wrong.
Not a huge issue either way.
Look at the bottom left, is it whit or gray?
Terry
It is gray (OFF). But I was thinking previous versions turned it on when you created a TNF. As I said its likely I am mistaken.
Rich, I think it has always been on off selectable. Even back to PSDR you could set one then need to turn it on. Or off1
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
