Heil PRb781 - Mic Bias?
Neil D Friedman N3DF
Neil D Friedman N3DF Member ✭✭✭✭
Heil PR 781 mic plugged into Flex 6600M balanced input (1/4 inch) connector.  Mic bias on or off? Thanks.
  • Bill N3HQB
    Bill N3HQB Member ✭✭✭
    edited March 2018
    Off.
  • [Deleted User]
    edited April 2020
    You only need the bias if it is an Electret mic
    The PR781 employs a Heil PR dynamic mic element . . . You do not need bias on
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Steve is correct.
    In fact, If you are using the 1/4-inch balanced connector, the Mic bias makes no difference, because no bias is applied to the 6600's 1/4-inch balanced connector, only to the 1/8-inch "pseudo-balanced" connector.
    Ken - NM9P
