Heil PRb781 - Mic Bias?
Neil D Friedman N3DF
Member ✭✭✭✭
Heil PR 781 mic plugged into Flex 6600M balanced input (1/4 inch) connector. Mic bias on or off? Thanks.
Off.1
You only need the bias if it is an Electret mic
The PR781 employs a Heil PR dynamic mic element . . . You do not need bias on
3 -
Steve is correct.
In fact, If you are using the 1/4-inch balanced connector, the Mic bias makes no difference, because no bias is applied to the 6600's 1/4-inch balanced connector, only to the 1/8-inch "pseudo-balanced" connector.
Ken - NM9P2
