SmartSDR for Windows mute 6600M internal speaker
Tom Wilkinson
Using SmartSDR 2.1.33 with FLEX-6600M V2.1.33.106. When I am using the radio's audio I would like to use headphones with no external amplified speaker plunged in. Using SmartSDR on the PC, when I click the speaker mute icon it will mute an external speaker, but if using the internal speaker it will not mute the internal speaker.
Can the 6600M be updated to mute the internal speaker when the mute icon is clicked on SmartSDR for Windows in radio audio mode? Or am I doing something wrong or have I overlooked a setting?
Thank
Tom, N8FDY
Thank
Tom, N8FDY
first
go to 'menu' then 'audio' and disable front speaker
before starting ssdr for windows
Yep I agree seems like an upside down way to do things (hi hi)1
yep...
did that on purpose just to get attention ;-)0 -
Actually on the smartsdr upper left corner under settings there is a radio tab i believe it is and if you click on it one of the boxes says front speakers and beside it is a button labled enable click on it and it goes ro disable and the radio speakers turn off but i think only if your not using pc audio through your computer if i recall right.0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
