New to Flex SDR radios, Question on SmartSDR and 6400M
Thomas NE7X
I am new to Flex and SmartSDR, so I have a basic question.
I have a pre-order for a 6400M. My main interest in purchasing the "M" model was because I do not want it to be a requirement to use an external PC to operate the radio. I want the radio to be 100% stand-along and not tethered to a PC for operation. Its OK to required a PC to perform updates and configurations to the radio, however once the update has been performed, I want to dethatch the radio from the PC.
QUESTION
When the radio is connected to the PC and I make configuration changes (Example: To the Panadapter colors) using SmartSDR, and then disconnect the PC from the radio, will the changes made under SmartSDR stay configured on the radio?
NE7X...
QUESTION
NE7X...
Most configuration changes are stored in the radio. Some configuration changes are "client" specific and are stored locally. By client, I mean the interface that comments to the radio, be it SmartSDR for Windows, SmartSDR for iOS, a Maestro or the front panel of an M series radio (SmartSDR-M).
Since I will only be using my 6400M in "stand alone" mode, do I still need to purchase a SmartSDR license in order to perform firmware updates to the radio?
the 6400M already includes a V2 SSDR License2
In fact they will only run v2.1 and above. When v3 is released and I have my 12 slice Flex 9700 with the power genie 3.0* you will have to pay to upgrade. *not a forward looking statement0
You really should try SSDR on the PC also... You will be amazed at how much better and more useful it is than the knobs.
Yes I understand how hard it is to break old habits..
I have had a Maestro since the beginning.. Yes.. knobs are a bit faster in contests.
BUT for everything else a big computer screen with everything easily at your finger tips is so 21st century better and more useful...
BTW.. I would never want to work a DX pileup again on a tiny screen with knobs - so much quicker to see the bands, click and jump in the right spot to work the dx on the first call...
I never understood the fascination with knobs in contesting. I work faster with N1MM arrow keys. Ria N2RJ0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
