Brand spankin new guy here. Are you able to key the mic through the software?
Chris H
Ordered my Flex 6400 on 2/25/18, Im getting all my ducks in a row because I know I got a while before I get it. Chomping at the bit. Anyways getting my mic/headset/PTT setup squared away and I was wondering if your able to key up the radio using a button in the software? Specifically, I have a gaming keyboard that can be programed with macros and was hoping to assign a hotkey to the PTT button in the software. I scanned the manuals and couldn't find anything really and its likely so obvious that they didn't waste the ink to state it. I know VOX is an option I just want to have a hard key for PTT on the keyboard and save a few bucks by not having to buy the RCA jack PTT for the backside plug. I saw references to hotkeys in older posts for older Flexradios and was just hoping that something has been implanted specifically for the 6400.
Chris
KI7UVV
Chris
KI7UVV
It's called the MOX button
PTT switch's can be built for about $10.00 depending on the switch you use.
Well worth it in my book, the MOX get's old very quickly
If you have a OLD Video / Audio cable with RCA jacks on it from an OLD VCR then you have the wire and the connector you need, just have to add a Momentary N.O. Switch.
Bret
WX7Y0 -
You could send an API command via a batch file to the radio via the network to make it happen. Maybe even a Cat command. Just thinking out loud.
Thanks folks.0
Or click on mox once on and off, after that you can key the radio with the space bar.0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 191 FLEX-8000 Signature Series
- 913 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 955 Third-Party Software
