Smartlink Login
Rich McCabe
Member ✭✭✭
Not sure if there are issues with the Smartlink server or I am doing something wrong. Flex sent me a 6600 to replace my failed 6600m. It arrived today and everything seems to be working OK so I want to register it and get remote working. I had logged into to the first 6600 as it showed my gmail avatar but I did not attempt to use it remote.
So I am trying to login to Smartlink now and it just returns back to the login box. I assume the password is same as my Gmail account but sent a password reset request which never came. I tried to add a second dedicated Gmail account but same results.
Rich
Rich
Rich - try registering without depending on Google. Some folks have been reporting the Google authentication as inconsistent. I set mine up separately from Google and all has been well. GL and pse report back. 73 Steve K9ZW0
Steve,
Thanks for response. Just created an account using a non Google email and got the Verify your account email and clicked the verify link. Received the "Your email was verified. You can continue using the application" message.
Try to log in and does the same thing which takes me back to the login box. Tried it from my shop computer and same problem. Opened my notebook to find it was still logged into the original account. So I logged out on that machine and it wont log back in now either.
Rich
Try logging the radio out and re-login in with the non Google account you just created. You will need to be in front of the radio to use the PTT to log it out and back in! Bret WX7Y0
I have even tried power cycling the radio, rebooting, etc. Wont hold the login.
This issue has been fixed in SmartSDRv2.1.33
https://community.flexradio.com/flexradio/topics/smartsdr-v2-1-33-now-available0 -
Thanks Tim. No big deal. You are supposed to be resting.
Rich
I am resting and making good progress healing from surgery.
This is a serious issue and I wanted to make sure the Community was made aware that we know about the problem and are actively working on a fix since this is a global issue.
Time to stop typing. It took me 15 minutes to write those 2 paragraphs with only a left hand :-O 73
And, he typed that all with 1 hand!
Hi,
after one day, SmartLink login still not working. Any estimate when the the serivce will be available again?
Day two for me. Began Tuesday (3/13/18) here. Anyone else still having this issue?0
Stand by. We understand the issue and a fix is being tested. So sorry for any impact this may have.0
Thanks Mike...appreciate the update
My Smarlink quit yesterday. Changed to non-Google account today. Still having issues. Thanks for posting that this is known problem being worked.0
Apparently the fix you have been testing does not work. How about restoring a bare metal backup from last week…!!! That should have been done early yesterday...
David, how do you know the testing does not work? You don't know who is testing it do you? I agree that a backup to something that works should happen.
The fix is a SmartSDR fix, not a service side fix. If we could do it on the server side, we would do that as a priority. Again, sorry.
Yes...Very disappointed in the time it is taking to correct this problem.
Tuesday night went to a friends house and met several hams there; was going to show them how I could operate my new 6600 over the Internet. I had built up how great it is.....needless to say was pretty embarrassing after the build up I had given it. They were still eager to see it and were hoping we could get together Wednesday night, but I told them still not working.0
Will be a new version of SmartSDR to fix this problem?0
Where was SmartSDR changed? Not on my computer or Flex Radio! Are you saying that we should expect an update to SmartSDR to fix this? This would be a real issue while traveling away from my home QTH.0
Michael, not questioning this but as a technical minded group I am curious to how this is a SmartSDR issue. We have not had any SSDR updates that I am aware of that broke this. It was working on this version of SmartSDR before.
It seems to me that something had to change on the server side and you are testing the Fix on SmartSDR. Is that correct?
Why do you guys keep drilling down on everything he says, just let them work on, they know a lot more about it then we do. Remember it's just a fun hobby.0
Apparently they don't ... This is taking a very long time to correct whatever they changed in their software. Yes this is a hobby but open discussions are a big part of it.1
LOL at Bill
Im not bashing Flex but that just seems to be the norm . . . Not Working . . . Not Working. Issues with new radios,Smart SDR login not working, bluetooth in Maestro not implemented (hardware supposedly there, Smart SDR random disconnects, one user is on his 3rd Flex 6600 series it just goes on and on and on. I have my own issues here with the disconnects and no wi fi networks available but I just deal with them.
According to Tim there was a change on the Auth0 authorization API that is used to log into SmartLink. While none of us know for sure, it sounds like whatever changed that broke the SmartLink login cannot be changed back and it looks like (from the comments above) the issue will need to be resolved on the SmartSDR side. As Rich said, since this is a technically minded group, we are naturally curious as to what is going on, and while this is not a business critical product (after all, it is a hobby) we still are interested in finding out what it will take, and how long, to get this resolved, especially since we have, patiently, waited so long to get V2 and/or our new 6400/6600 radios!1
This is not the first time I have seen people think they know more about Flex related problems then Flex does..Lol1
This begs the question....when I bought the radio I bought it specifically because of the RC ability...I was surprised by the 'secure login' system vs me connecting directly to my radio. I'm assuming there's a reason we can not do that, and that its associated with the use of their software. Is there no other way to do this? In my situation, RC only, my access...to my radio online...is at their mercy. Not ideal. Perhaps a plan B should be available.
Just want to understand what is going on.0
I think the reason for a third party service system is to avoid users trying to connect directly. Direct would require dynamic DNS (in most cases) and other network changes to make this happen.
This should be the simplest and most reliable method.
- 323 Community Topics
- 578 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
