Multiple WSJT-X working but band indicator is RED
Wim
I have multiple WSJT-X instances running on my 6600 like I did on my 6500 before.
I use the WSJT version provided from WO2X with the hamlib changes to support the new radio models.
I'm using the TCP port numbers different per-slice.
First instance completely works fine, second and third instance work fine to read the frequency of the slice, transmit and receive audio but the band indicator is shown in red and the drop-down button to set the band is empty ..
Has anyone seen this, and what might be the issue ?
Clicking testCAT or testPTT also works fine.
Check you have Frequencies saved in settings
Interesting .. the two other instanes have those frequencies list in settings empty
for some reason... the first instance has 120 entries there... will see if there's an
easy way to copy them over...
But that seems to be the issue indeed, thanks for pointing that out1 -
In the instances with missing frequencies, go to Settings / Frequencies, and right-click on the frequency list. You will see a "Reset". Clicking on that reset will repopulate the frequency list for you.0
ok, that's probably the easiest repair... maybe my INI file got corrupt and that list disappeared.. a bit weird .. but up and running again now. thanks for the help0
There was a release candidate or two of wsjt-x that lost the frequency settings some time ago. The same technique was recommended to fix that problem, so this carries over to running multiple instances quite nicely. Also gives you a way of reverting the the "standard" setting for frequencies if you have been experimenting.0
I'm Glad you're Back in Business
Cheers!
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
