Flex Maestro Factory Reset
Hi All,
A Maestro unit has recently come into our possession to go with our Flex 6300, due to a very generous donor. However it looks as though there's a software problem on it, as it doesn't seem to want to boot up properly.
Is there a way to perform a full factory reset on the Maestro unit at all? I know the tablet inside is a Dell Venue 8, and that the tablet itself should have a factory reset routine, but does anyone know whether FRS use a separate OS image that contains a base version of Maestro and will work with a standard reset, or whether it's a separate application that would need to be installed afterwards, along with custom drivers for the hardware? Obviously we don't want to render it irrepairable, but in the current state, it won't boot properly at all. On power-up, the backlight comes on, a spinning disc is then visible, followed by a mouse cursor, and then a 'swipe down to shut down' type screen. No sign of any Maestro software loading or anything.
Any help would be appreciated - we just want this to work! If we need a custom image or something, then perhaps FRS would be willing to send us a soft copy to install?
John
John
Hi John
There is no factory reset. If you think you have an issue, please open a support case so we can address it.
While you are booting, make sure it is plugged into the wall adapter and on a LAN connection. Hold down the power button for 5 seconds to power it up.
That is about all the user interaction available.
Hi Mike,
Thanks very much, will do. As a point of feedback for the future, it might be worth adding a function to perform such a reset?
John
I would imagine a "Dell" factory reset would still make it inoperable as a Maestro as now there would be no driver's for the Flex hardware. And a "Flex" factory reset might introduce so many other issues that Flex decided not to offer a "reset" path.0
That was my suspicion too, hence asking the question
Hopefully we'll get something out of Support for it!
If it has not been plugged into power for a while, the internal battery may be discharged.. Plug it into the power source for an hour or so, then try to boot it up..
AL, K0VM
We had that problem originally, but got past it already! Left it charging overnight. But now we're getting the strange behaviour I mentioned at the start of the thread.
John
John, is the unit still under warranty? I had a similar problem with a new unit and had to send it back to Flex. I was told that there was a loose connection between the tablet and the Maestro hardware. If it is not under warranty and you feel capable, open it up and check all connections. That may save a trip back to the factory.
Good luck.
You should open a helpdesk ticket with Flex..
AL, K0VM
Why does it need wall power if it has a good battery?0
This has been discussed with engineering and at the moment, based on the design, there really is no requirement for a reset. They feel that that way the unit performs now, that this achieves all that is required.
HI FELLOWS, THE SCREEN TOUCH SCREEN OF MY M A E S T R O THIS TO FAIL TO TOUCH THE VERTICAL LINE WHERE IS THE MENU .... when we touch that point it does not work .. the rest of the screen works normally, is there any hint for this ?? maybe a reset ?? thankful
-1
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
