6600(m) cw mode memory buffer
Rej va2am
6600(M) stand alone, can we store short cw messages like Call 599 report for dx?
or do we need to install a third party software?
Thank you
Thank you
There is a CW memory function key that you can program (F1-F6). So I would assume you could program 6 memories if you used all the Function keys.
F1-F6 store functions like Vox on or off etc etc. I cannot find any cwx or cw memories. I use FRStack which does provide that for the 6400M. I suppose it is the same for the 6600M? Unless I am missing it!
"SEND CW" Third from bottom on mine.
Rich-- third of bottom where? I have the 6400M and cannot find a place to store cw memories?
I take it CWX doesn't work when the rig is run with the Maestro. If it's needed, maybe you can run the rig from a PC SmartSDR when you need CW buffers.0
Ill have to see how that works! I have other things programmed there at the moment. Never thought of CW!! thanks
figured it out! works...
It does not. If Flex ever implements mulit-client where you can use knobs and SSDR at the same time then it should but currently its either or.
Rich
Is there a way to halt the CW memory transmission before it completes?
I assume you're talking about CWX. If so, hit the ESC key. Stops it immediately.
(Edit) - oops, looks like we're talking Maestro - missed that.0 -
Hi Duane, Thanks for the reply. I am using the front panel function keys to send CW macros from the front panel of a 6600M. I am wondering if there is a way to terminate a transmission part way through the message from the front panel. Thanks, Geoff
Yep - sorry Geoff - I missed the context when I posted. Since I don't use a Maestro or an "M", I'm only familiar with CWX. Someone here will have an answer for you, I'm sure!0
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 997 Third-Party Software
