Only the lower half of the VFO freq numbers showing
Bob W8RMV
When using the 6400M in PC mode using v2.1.32, the flag & the panel showing the VFO frequency, only shows the lower half of the numbers. I checked here to find a missing font as a solution, I verified that the computer I am using does have the SF font. But I d/l'd it anyway & installed the Font anyway. But no joy. Any other suggestions? 73 Bob
Try changing to a higher resolution on your video card.0
I have the same problem on my laptop. I have a higher resolution machine and display scaling is on, so my guess is the application isn't handling this well. Turning it off isn't an option as it makes text unreadably small.0
If you are using a large monitor, Windows (8 and greater) will do automatic DPI scaling that can affect the display in this manner. Just manually adjust the DPI setting for your monitor.0
Monitor is running 1920x1200 (which, ironically, is the native output of the HDMI port on the 6400M and the Monitor) while connecting thru the LAN. Also running a fully updated W10 64bit computer wireless. Don't think it is a monitor resolution issue. If 1920x1200 is bad for v2.1.32, then why would Flex output at that resolution? Thanx - Bob
This is configured manually to 150% on my display (minimum text is still readable), and this problem still persists.0
It isn't a resolution issue, it is a DPI scaling issue.0
OK, I looked at my Radeon RX480 settings & there is only one GPU Scaling adjustment I could find & I tried it both ways & it had no effect. I tried several Windows text scaling options & that had no effect either. I do not see any option for DPI scaling in Windows or Radeon. Open to options. Thanx Bob W8RMV
Have a look at your fonts folder, do you have Napoli font? I had the same problem on my Dell Win10 laptop. This Napoli download solved it:
https://www.flexradio.com/downloads/napoliserial-xlight-regular-zip/
Also look at your system settings, screen resolution should be at 100%.
Also look at this:
https://community.flexradio.com/flexradio/topics/partial-frequency-readout?topic-reply-list%5Bsettin...
Bob.. If I remember correctly some Windows programs were missing a certain Font DLL that fixed this particular issue. try searching the Community for DPI scaling issues or maybe someone with a better memory will chime in on this.
GL,
Larry k1UO0 -
The font did it!!! I tried another that I found searching this site & that didn't. Thanx Bill!!
73 Bob
Sorry I missed the font issue. It would have been more evident if I could have seen the entire slice display. Glad you got it working.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
