DDUtil Error with SteppIR SDA-100
David Ahrendts
Lost in the weeds on this one. Was working -- now not.
Using DDUtil 3.2.6 and my Flex 6500 just to control the SteppIR SDA-100. "Connect to CAT" produces this error message:
"Cat Server Connect Error! No connection could be made because the target machine actively refused it. 127.0.0.1:5002. DDUtil_V3"
What is that?
David A., KK6DA
That error means that DDUtil could not connect to Smart SDRCat. Suggest doing a PC re-boot which should fix things.0
Re-booted. Same error. Seems something a little more persistent. Suggestions?0
Either SmartSDRCat is not running or it has a problem. Open its UI and check to see it has a TCP port 5002 which should be a default it's setup with. If it doesn't have one create it.
Bingo! Somehow (not my fingers) port 5002 became 6000. Changed to 5002 and we're happy. Still not talking to the SteppIR, but I think I can take it from here. Thank you so much, Steve.
David A., KK6DA, LA0 -
Black Magic, Voodoo, Gremlins0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
