DDUtil Error with SteppIR SDA-100
David Ahrendts
David Ahrendts Member ✭✭
edited April 2019 in Third-Party Software
Lost in the weeds on this one. Was working -- now not.
Using DDUtil 3.2.6 and my Flex 6500 just to control the SteppIR SDA-100. "Connect to CAT" produces this error message:
"Cat Server Connect Error! No connection could be made because the target machine actively refused it. 127.0.0.1:5002.  DDUtil_V3"
What is that?
David A., KK6DA
  • Steve - K5FR
    Steve - K5FR Member ✭✭
    edited April 2019
    That error means that DDUtil could not connect to Smart SDRCat. Suggest doing a PC re-boot which should fix things.
  • David Ahrendts
    edited December 2018
    Re-booted. Same error. Seems something a little more persistent. Suggestions?
  • Steve - K5FR
    edited April 2019
    Either SmartSDRCat is not running or it has a problem. Open its UI and check to see it has a TCP port 5002 which should be a default it's setup with. If it doesn't have one create it.
  • David Ahrendts
    Bingo! Somehow (not my fingers) port 5002 became 6000. Changed to 5002 and we're happy. Still not talking to the SteppIR, but I think I can take it from here. Thank you so much, Steve.
    David A., KK6DA, LA
  • Steve - K5FR
    edited April 2019
    Black Magic, Voodoo, Gremlins
