DDUtil Error with SteppIR SDA-100
David Ahrendts
Lost in the weeds on this one. Was working -- now not.
Using DDUtil 3.2.6 and my Flex 6500 just to control the SteppIR SDA-100. "Connect to CAT" produces this error message:
"Cat Server Connect Error! No connection could be made because the target machine actively refused it. 127.0.0.1:5002. DDUtil_V3"
What is that?
David A., KK6DA
That error means that DDUtil could not connect to Smart SDRCat. Suggest doing a PC re-boot which should fix things.0
Re-booted. Same error. Seems something a little more persistent. Suggestions?0
Either SmartSDRCat is not running or it has a problem. Open its UI and check to see it has a TCP port 5002 which should be a default it's setup with. If it doesn't have one create it.
Bingo! Somehow (not my fingers) port 5002 became 6000. Changed to 5002 and we're happy. Still not talking to the SteppIR, but I think I can take it from here. Thank you so much, Steve.
David A., KK6DA, LA0 -
Black Magic, Voodoo, Gremlins0
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
